By Lou E
#83710
Remove timing cover/ undo the nut in the center of the mag sprocket/keep unscrewing as this acts as a jackscrew against the end of the maneto armature shaft, and pulls the sprocket off the taper.....
By vince
#83765
Hi, the self extractor are on A/R sprockets. If you have a manual advance ,the sprocket should have a internal thread for an extractor. Alternatively give the sprocket a light tap with a hammer it may come off depending how tight the tapered fit is! Vince
By gak
#83774
Thanks Vince
Yes that is what the sprocket looks like. By any chance do you know what the sprocket's internal thread is as I've tapped and used a puller without effect. Geoff
By vince
#83778
Hi, I think the extractor is the same as that for a bullet, if I can find my spare sprocket I'll check. Vince. Ps did you give the puller a thwack to shock the taper?
By gak
#84005
Eventually had to make a tool to release the sprocket. Internal thread of the sprocket is 5/8 BSC if anybody is interested. Mag away for repair.
Thanks for those who replied. Geoff
