- Fri Jun 21, 2019 9:09 pm
#83664
I have a 1966 interceptor custom 0.10 overbore fresh mag and carb. Runs great. 2 months ago it started a half-time knock, loudest at the rocker shaft oil banjos. I have run the engine with the primary cover removed and the knock is not the primary chain tensioner foot. Been through the valve adjustment twice, springs on sides of rocker arms are intact. Pulling a plug wire does not change the noise. What DOES change the noise is leaning the machine to the right (noise DISAPPEARS). returns in upright orientation, LOUDEST while on sidestand (Thus the conondrum). I have had to disassemble the machine in the past to discover what creepy problem was designed in that other M/C's do not have.Would appreciate it if someone has solved this one before.........
