By Slappy
#83523
Good afternoon all
Just a quick question I have got the primary case off at the moment and in the work shop manual it states that the chain should have 1/4 inch free play on the top run
is this adjustment correct or does it need to be more, when I first checked it was about 3/4 inch, I did think 1/4 seemed a bit tight
many thanks Dave.
By vince
#83524
Hi, 1/4 is correct. ie rotate the primary chain slowly and find tightest point. Bear in mind even wishbone tight you will still be able to move it . So it's a loose 1/4 !! Vince.
