Treps wrote: ↑Sat Aug 29, 2020 6:43 pm
I am also having the dead battery problem after 4 or 5 days not riding
This is not uncommon. I've put an isolator switch on the earth and that has resolved the problem. When I checked for current drain, I found it was greater if , as I usually do, my bike was left in first gear when parked. I honestly couldn't be bothered with the palava of spending hours looking for a "problem". Last time I looked, there were a few YouTube clips of folk moaning about the same issue, and apparently some say a Lithium battery helps. The original battery in mine failed after 6 months, so it got a Lithium replacement. Personally I think the battery should be higher capacity for an adventure bike, and if I was going off grid with mine, there's enough space to mount an "auxiliary" boxed battery between the right hand pannier frame and the rear bike frame in a tidy fashion , and use the current battery compartment, which looks like an afterthought, for storing spares, bulbs cakes etc.
