250 Crusader / 350 Bullet
Posted: Sat Aug 04, 2012 8:01 pm
by Peter
Silly question possibly but is the frame the same?
Posted: Sat Aug 04, 2012 9:24 pm
by John M
The Crusader frame is a slightly smaller version of the post 1956 Bullet frame. The Bullet engine will fit with modifications to the frame, but it's not straight forward.
http://www.flickr.com/photos/24439520@N03/4817252115/
Posted: Sun Aug 05, 2012 1:40 pm
by Peter
What about the clipper frame, does anybody know if that is similar to the bullet frame. Thanks John for the prompt reply.
Posted: Sun Aug 05, 2012 3:56 pm
The 1956 only Clipper frame is the same dimensions as a bullet but is all welded with no lugs, even the steering head is a tubular fabrication. It has additionally a bracing tube like the 250. There is one on ebay now. Just to confuse matters there is a third frame (ie different to the 250s and Bullet/Twins) which was made for the 1958 only Meteor Minor and is halfway in size between them. It was fitted with the 250 toolbox and mudguards and has a unique seat subframe too. "Clipper" wasn't the name of a definite model, it tended to describe the budget version of a particular range so you could have a Crusader Clipper, a 350 Bullet Clipper, etc.
