- Fri Feb 24, 2012 10:38 pm
#92
Hi guys---- just give me some thoughts on this one please ? My bike is a 2005 Classic 500 with 7,000 miles on the clock. During the winter months I've fitted }------ 2 x Phos.Bronze valve guides, 1 x Hitchcocks O/S exhaust valve, 1 x original inlet valve, Cyl. head generally cleaned up, both valves properly ground-in and checked. Composite head-gasket, Hitchcocks 8.5 forged piston, 3mm compression plate, original iron barrel honed and re-fitted. Oil & filter changed (20w/50 Comma), New plug--0.025", timing checked, points gapped at 0.015". It has the transistor-assisted pack fitted by previous owner. So what's the problem ??? After warming up ( and a clean exhaust) it smokes at idling-----not a lot such as wet sumping might give, but just a hint of blue in the exhaust. My instinct says---------"new rings settling-in to a used(slightly) bore"-------------- What do you think ?? Have I missed something ?? I had bought some valve stem seals from Mr H but, despite some "tech-help" from them, there was no way they would fit-----just too damm small. Any comments ?? Cheers me dears.
