Barryeggs wrote: ↑Sat Jun 08, 2019 10:28 am
So Stinkwheel, you think the Hitchcocks pressure relief kit is a wothwhile investment?
Not really sure. I fitted them to both my bikes. Perhaps paranoia too? Although scavenge-pump overpressure is a well known issue and a reason for a lot of pump drive/engine failures. I believe the original design had an internal relief valve fitted.
I'm also running samrat rockers as pressure fed, unmodified with the O-rings in place meaning there will be a much higher tendancy for the scavenge side to overpressure. Standard rockers are more leaky and effectively volume fed. The oil is being forced out through a pretty small gap on the samrat items.
Proof of the pudding? My 350 motor did over 80k miles before catastrophic engine failure due to a snapped valve through an apparent fatigue fracture at the friction weld. I did not give that motor an easy life, towing, motorways and protracted runs at full throttle. The original floating bush big end is fine, no perceptible play. The crank is scrap but due to a loose drive shaft, nothing to do with an oiling issue. I'm rebuilding it now. It will have standard oil pumps and the scavenge-side pressure relief again. I'm using a needle roller big end so the pressure on the feed pump is now negligeable.
