Minimul oil level
Posted: Mon Jun 03, 2019 6:36 pm
by Perorec
Hi, can you tell me what is minimum oil level iron cast bullet 500 can run without making damage to machine too fast?
I was on a ride and when came back home I realised oil level was bellow minimum level on dipstick. After few measurement dipstick was completey dry although after one meauserment there was a little drop of oil at the end of dipstick.
Really paranoid since I got my motorcycle back after engine rebuild.
Thanks
Re: Minimul oil level
Posted: Mon Jun 03, 2019 6:42 pm
by Wheaters
If it's not making any unusual noises, I'd just top it right up and not worry about it.
But keep a more regular check on the oil level!
I check mine every time before every first start of the day.
Posted: Mon Jun 03, 2019 8:15 pm
by Chris Tindal
If you want peace of mind it may be worth checking the oil filter. If there's no metallic dandruff then all is ok.
Posted: Tue Jun 04, 2019 1:23 am
by Leon Novello
A loss of a little more than 1 litre will drop the level off the dipstick, any more, and the engine will begin to overheat.
I had a thermometer with the probe through the oil reservoir drain plug. On one ride, the temperature suddenly started to move the indicator swiftly across the dial, so I cut the engine and coasted to a stop.
A kind lady in a utility pulled up and offered to go back and buy two litres of 20/50 for me. It took a whole litre and a bit more from the second bottle to bring it up the to the top mark on the dipstick.
anonymous photo sharing
Posted: Tue Jun 04, 2019 6:35 pm
by Perorec
I checked how much oil was missing. After adding 300 ml of oil there is now a little over half of the oil on dipstick. So it should be ok right? 300 ml of oil can't make that much difference?
Posted: Tue Jun 04, 2019 8:55 pm
by Wheaters
See the previous answers? ;)
