68 Interceptor 750 Series 2
Posted: Sun Jun 02, 2019 7:02 pm
by kgdb
Hello, new guy here. I have a 68 Interceptor 750 Series 2 and I was wondering if anyone makes or carries a electronic ignition system for this motor?
Thank You
Re: 68 Interceptor 750 Series 2
Posted: Mon Jun 03, 2019 9:22 pm
by RocketRR
Hi yes mine has a Boyer fitted I would give them a call.
I believe Pazon also do a system that fits as well.
The Boyer was easy to fit in my experience and timed up really well.
Posted: Mon Jun 03, 2019 10:04 pm
by kgdb
Thanks for your reply. This morning I had a reply from Boyer, see below. I will see if I can find anything on the Pazon system.
Thank you for your enquiry,
We don't make an ignition kit specifically for this machine but parts can usually be supplied for conversion to Electronic ignition.
Basis of the conversion would be an ignition kit from the unit construction Triumph twin with side points (KIT00052). The kit is for a 12 volt electrical system, if not 12 volts, 12 volt conversion info can be provided.
The original ignition coils can often be used, or 2 new 6 volt coils (COIL00003) can be supplied as an upgrade.
KIT00052 contains our standard magnetic rotor with a male 'Lucas taper' fitting. The supplied stator plate that will replace the contact breaker plate is a 2.7" diameter part. These fittings should be checked on the bike as other alternatives can be supplied (Female taper rotor and 3" stator plate) if required.
Regards,
B.B. Tech.
Posted: Tue Jun 04, 2019 1:46 am
by kgdb
Rocketry, did the magnetic rotor with Male taper that was supplied in the Boyer Kit00052 fit your Royal Enfield or did you have to get a different magnetic rotor (female taper) from them? Thanks again
Posted: Tue Jun 04, 2019 7:15 am
by Dan H
Thank You
Try part number "BOYER" or see the link below, I have had one fitted to a Mk2 Interceptor for some time now and it works great.
http://accessories.hitchcocksmotorcycles.com/13764
Posted: Tue Jun 11, 2019 9:58 pm
by RocketRR
Sorry for late reply yes same as I have fitted.
Posted: Wed Jul 03, 2019 3:37 pm
by sherm_des
have a look at power arc. they make an optically controlled ignition system. I have it on my bullet and it works great.
very easy to setup and works very well even at low voltages.
http://www.powerarc.com/ids/cdl2.html
