Engine studs
Posted: Sat May 18, 2019 10:59 am
by SkinnerHolden
Right!! Bravely going where I have never gone before!!! The head is safely off. I need to change the engine studs... how do you remove them? Thanks. Iain :roll:
Re: Engine studs
Posted: Sat May 18, 2019 7:41 pm
by Chris Tindal
Tighten two nuts down onto the stud, then with a spanner turn the bottom nut anti-clockwise to untighten. It shouldn't be able to travel up the thread because of the other nut stopping it, resulting in turning the stud instead. It can be a bit tricky to stop both nuts untightening together, but you'll soon get the hang of it.
Re: Engine studs
Posted: Sat May 18, 2019 7:49 pm
by Chris Tindal
If you're replacing them it may be worth fitting the modified ones with the square ends. With these you can tighten and untighten them easily with a socket and it saves the faf with two nuts. Bighead engines had them as standard but I think our host do them for the other iron/ classic engines.
Re: Engine studs
Posted: Sat May 18, 2019 7:55 pm
by stinkwheel
If they aren't going back in again, you could just use mole grips.
Two nuts will often work.
The proper tool would be a stud extractor. I use the type with tapered rollers in a socket. They can cause a bit of galling on the stud though. They can damage a threaded section quite badly but I find if you're using them on a plain stud section, it's nothing a bit of a rub with some emery paper wont fix. I slide them as close to the bottom of the stud as possible and put a spanner on them instead of using a ratchet handpiece to reduce the chance of shearing the stud. In this case, a ratchet spanner in use, Posing for the photo, I slide it nearer the bottom for actually extracting the stud.
A set of stud extractors is one of those little tools you don't use very often but that doesn't cost much and gives a warm sense of satisfaction when you can pull it out of the cupboard of "special" tools and use it. Mine were about £20 from machine mart as I recall, 6,8,10 and 12mm. I've used them more often for removing exhaust studs from Japanese bikes.
Of course, if you're replacing them with our hosts ones with the square end, you can wind them in and out using a reversed 1/4" drive socket and an allen key.
If it's a classic engine, remember to run a drill through the cylinder head washers before re-fitting them. Even with the hardened ones, they can land up VERY stuck as I found recently taking the head off my 350.
Re: Engine studs
Posted: Sun May 19, 2019 9:44 pm
by SkinnerHolden
Thanks guys. Giving these a try tomorrow
Re: Engine studs
Posted: Tue May 21, 2019 5:39 am
by SkinnerHolden
Borrowed a friends extraction tool and all has gone well so far. :D
