- Thu May 02, 2019 3:27 pm
#9285
I'm renovating my old 2007 350 bullet. It's had a hard paper round and since the engine is out, I took the rest of it apart too for a clean up, repaint and re-task as a light road-trials machine.
The frame is going to need partially stripping and repainting too because there is a fair bit of rust about. Seems like an ideal opportunity to brace/weld any weak points, especially if I'm going to start throwing it up steep gravelly hills and along stoney, rutted dirt tracks. Where should I be checking for existing damage/cracks? Anywhere I should beef up just in case? The triangular plate with the hole in that the swingarm bolt goes through could stand being meatier if I'm any judge?
