Noise in top end
Posted: Sun Apr 21, 2019 2:05 pm
by SkinnerHolden
Hi all. I have an 86 Indian RE Superstar 350, although it is a bit of a bitsa. Having solved quite a few issues, faster a short run, power drops and a strange tinkling noise comes from the top of the engine and running starts to become a little erratic. I have heard rumours of valve seats working loose. I’ve this likely or is it something else entirely? Help, I am loosing patience as I am no mechanic!
Noise in top end
Posted: Sun Apr 21, 2019 3:02 pm
by stinkwheel
It is not unheard of. Mine did it and I've spoken to others who have has a similar issue. I got a lot of popping and banging on the overrun too when mine did it.
Noise in top end
Posted: Sun Apr 21, 2019 3:43 pm
by vince
Hi, possibly a sticking valve stem. Vince
Noise in top end
Posted: Sun Apr 21, 2019 9:34 pm
by SkinnerHolden
It is 89 not 86 if that makes a difference!
Noise in top end
Posted: Tue Apr 23, 2019 3:35 pm
by SkinnerHolden
Thanks Stinkwheel... how did you solve it?
Noise in top end
Posted: Fri Apr 26, 2019 1:06 pm
by Super45
basic hings first, have tappets been adjusted? when was it last serviced with a new plug? I is it misfiring when it does it or just hunting a bit? has it ever had its head of for a decoke (build up can cause predetonation also know as pinking which will be a metallic ticking sound outside of the normal enfield clatter)
Noise in top end
Posted: Sat May 04, 2019 12:36 pm
by SkinnerHolden
Rocker covers off and found the culprit, a loose engine bolt! So Loctite bought, but I can’t find my blinkin’ torque wrench!!! Grrrr
Noise in top end
Posted: Sat May 04, 2019 1:05 pm
by grindstaff
That's a result, well done! Whereabouts are you? Maybe someone on here is nearby and can lend you a torque wrench.
Noise in top end
Posted: Sat May 04, 2019 9:01 pm
With the name SkinnerHolden I'm tipping southern Aus somewhere
