Page 1 of 3
Investing in a spare Electra Engine
Posted: Mon Apr 01, 2019 2:41 pm
by Cov Lad
Having read the many horror stories about Electra X's I wondered if it would be wise to buy an engine that has become available. I know that the engine is a 2007 leanburn engine with the carb primary cases & starter motor, but without the gearbox. Would this engine go into a 2006 Electra X?
The engine has done just over very little mileage. If hopefully I didn't need to use this engine will it deteriorate as a result of being sat in my garage or is it worth a punt? I also thought I could use the head to fit a proper decompressor as shown by Adrian.
Posted: Mon Apr 01, 2019 4:18 pm
You will have to decide whether you like your newly-purchased Electra-X enough to reckon that it's a keeper (not in the zoo sense).
If your decision is "yes", the 2006 and 2007 engines swap over happily, so get the spare engine and primary. Chuck a little oil down the plug hole and turn the engine over occasionally, it will be fine it it's kept in the dry.
Posted: Mon Apr 01, 2019 4:23 pm
And if you DO buy the spare engine, DO NOT be tempted to buy a spare frame with V5C, That way madness lies.
Wibble.
Posted: Mon Apr 01, 2019 6:58 pm
If it is cheap enough probably worth the punt, but just the fact it is being offloaded to me I get a feeling the big end has failed and you will never know till you fire it up
Posted: Mon Apr 01, 2019 7:09 pm
by Cov Lad
I have been told it came out of a runner. Sometimes you have to go with trust I guess. What would you consider a good price Norm? (The gearbox has been taken off for the blokes own bike).
Posted: Mon Apr 01, 2019 9:10 pm
If you can turn the crank backwards and forwards a bit with the plug out, any suspicious clonks will require a convincing explanation from the seller.
Posted: Mon Apr 01, 2019 9:54 pm
I would like to know why it was removed, only good explanation would be from a crashed bike
Posted: Mon Apr 01, 2019 10:29 pm
by Cov Lad
Would you consider £600 a fair price for an lean burn engine from a crashed bike? It's one of those things you never find when you need it quick I guess, but then you have to live with it.
Posted: Mon Apr 01, 2019 10:54 pm
Cov Lad, I would consider that way too dear for an unknown motor, that is big bucks in my opinion, but I am not on the ground there so couldn't be sure, Adrian would be best to comment on it.
Posted: Tue Apr 02, 2019 9:20 am
Norm could if it's priced in Australian dollars. Meanwhile, in northern latitudes £600 seems like a lot, but at against that our hosts have got an incomplete Electra-X engine (no primary) up for a whopping £1,050 in the used parts section, though they're still listing new cranks for £521.40.
I would suggest you follow this one up but DO check it over, and see if he'll take £500 for it if it's OK.
