612 bullet first ride.
Posted: Sun Mar 17, 2019 7:33 pm
Holy shit!
I thought I MUST have mucked up my maths as I was fitting a 21t gearbox sprocket... Err, no. Even with a close-ratio gearbox it'll pull away with minimal clutch slippage then goes what I can only describe as utterly batshit mental. I genuinely don't think it needs a 5-speed box. There is sufficient power to fill in any gaps.
I'll own up to having decided to go for a "Hard" run-in. I warmed it up then put 90 miles of spirited riding on it today, stopping every 30 miles or so for a short cool-down and to see what else has come loose/fallen off. So yeah. It'll do 50mph in first, 70 in second. If you wind on the throttle below 60mph, you have to concentrate to avoid sliding back off the seat. The power deliver puts me more in mind of my old MZ supermoto (XTZ660-based motor) but with all the noise you'd expect from a well tuned brit single.
I am more than pleased with this bike and I can see why Bullet Whisperer calls them "ASBO", you find yourself messing with the throttle just for the joy of hearing it roar at you.
Only had a few things fall off, none of them major. Brake fluid reservoir bolt, toolbox bolt, tail light bolt and my bar-end mirror. A bit of shimmy coming out of a corner about 50 miles in alerted me to the fact that the swingarm pivot bolt was loose (which I definately torqued up, I remember doing it, something must have settled). It's going to need bar end weights.
Disappointed in the mirror, it was a proper Bumm one, they aren't cheap. It not only worked loose but the glass nearly fell out of it!
I now have a laundry-list of servicing/snagging to do before riding it again. I suspect I've just built a bike that does everything one of the new twins does, only more expensively, however, it's unique to me, oozes character and I'm extremely pleased with it!
