Pulled head studs
Posted: Fri Mar 08, 2019 2:02 pm
Hi guys. Amongst the electrical failures of last month on my 1996 Indian 535cc (dual coil and regulator) I’d almost forgotten the unexpectedly loose head nut (nearside, by the plughole) – which I thought had loosened after running in post-rebuild.br>
But NO. The stud threads are OK and it turns in OK up to ~15ft-lb then turns without going deeper (I only ever use ~20ft-lb using a tested torque wrench). On retrieving the stud, lots of curled pieces of aluminium meaning the stud has pulled out of the crankcase - gives that sick feeling!!<
So it must be Helicoiled or Timesert or Recoil or “an other type†of re-threaded studhole. I’ve read up on the several discussions on this board over the past 10 years and see it is possible with helicoil examples, but our hosts sell “Recoil†types which may differ from the helicoil examples discussed, hence my 3 questions below:
1. Can a Recoil thread repair be done with the engine in situ or must I remove the whole b***y lot (which I’ve just put together after work on the crankshaft)?
2. Can anyone suggest which is the better type of repair type to use? (note I am not interested in fitting a threaded insert unless I have to remove the crank etc).
3. Since the other 4 such threaded holes are all the same age, and all in the same crappy indian aluminium, do you think I should thread repair them too even though they don’t appear to need it now?
Any thoughts or advice?
Thanks, ChrisD
Thanks, ChrisD
