1971 bullet big end bearings
Posted: Mon Feb 18, 2019 7:51 am
by nickbarber
Hi All,
Just after some advice on my 1971 bullet 350.
I have found the parts catalog online showing the part numbers of the big end bearings and spacers etc etc, but does anyone have a diagram on what goes where?
Cheers
Posted: Mon Feb 18, 2019 8:16 am
Nick, are you talking about all the bearings including the ones in the crankcase or just the one in the con-rod and flywheels? And if the latter, do you have a roller bearing installed or a floating bush? In order to answer this last question the flywheels will need to be split!
Posted: Sun Feb 24, 2019 12:55 am
by nickbarber
Hi Mark. Sorry for the late reply! I'm after a diagram of the locations of all the bearings, spacers and seals on the crank shaft. The flywheels haven't been disturbed and is totally intact, it is the standard floating bush. I have the 350 engine totally disassembled in a box and I want to put it back together but I'm unsure of the locations of the spacers and seals. Hope somebody can help. Cheers
Posted: Sun Feb 24, 2019 8:59 am
Nick, I think that the Indian Bullet of this period is the same design as the late Redditch built Bullets built up until 1961. Therefore I'd suggest you get hold of a Redditch workshop manual for these models which has an exploded diagram inside the front cover. Check our Host's manuals section or if you are anywhere near NN12 (Towcester) I have a spare copy you could have?
