By scotty
#9059
Hi 2016 b5 500, book says 101 link chain ut when 101 links counted you end up with side plates instead of roller end, what am I doing wrong. The classic using same motor runs a 18 tooth gearbox sprocket instead of a 17 ?
By Leon Novello
#81098
What I would do is to move the wheel all the way forward, then wrap the chain on and move the wheel back until it aligns where you want it.
By Haggis
#81101
The 101 chain uses a 'half link' to give the correct length.
The 102 is made up from complete links.
I would imagine that there is plenty of adjustment available to able to fit a 102 chain.
Chain is a 530, 'o ring' or plain is up to you.
By Haggis
#81102
By ric
#81103
what can confuse things is the stock B5 chain includes the half link as part of the chain, not as an 'accessory' item so only a standard split link is required to join the ends. Any non standard chain for a B5 will require a halfling.
