- Fri Jan 18, 2019 3:44 pm
#9058
The last years i had a lot of trouble to get the '94 bullet front brake working normally.
Yes i know how to adjust the thing, ended up replacing the front drum, tried 6 pair of shoes with different linings, 3 sets of different cams, and today the brake went from working okay(new hub, original linings and cams) to 'virtually nothing'again.
The brake comes back to rest position and the drum was not hot when i came home.
The new drum is - for India level;- quite round.
I don't know the cause, nothing has run hot,
Is there an other brarke plate and drum which is morte stable(so non-enfield)that i can build in?
Also the 'new and improved'brake plate has far too much play in all 3 holes to expect normally functioning..
