By Pict
#9048
The one that’s come out has an oil hole in it, corresponding to a matching hole in the kickstart spindle. New part doesn’t have the hole. It seems good practice to have the hole, any reason why there isn’t one in the part as supplied?
#81262
Ignore Leon, he thinks it's funny. Holes usually drilled after bush is fitted, it would be difficult to get the alignment right otherwise! REgards, Mark
By scotty
#81281
Hi pict might give your brease trick a try got one of those cheapie 10 ton presseswhen the weather cools a bit39c in a metal garage a bit warm, also considering a suitable dynabolt to grip inside, depends how tight a fit it is in the hole, will let you all know or might just buy new one from india.
By Leon Novello
#81282
Try heating the case and stuffing some ice, dry ice, or even ice-cold water down the bush, somewhat similar to fitting them, where the bush is put in the refrigerator, and the case is put in the oven. If you are lucky, tappipg the case will cause the bush to fall out; if not, it`s a hacksaw or chisel slot, and chop it out.
It`s advisable, if working in a garage,to not let the customer watch as you chop it out.
