- Mon Nov 19, 2018 6:36 pm
#8944
Hello, I have an oil leak from the bottom rear portion of the oil filter housing on the timing gear cover. There appears to be a flat spot machined on back of the aluminum housing that is covered with a grey hard sealant (looks to be factory). This may be possibly covering some sort of oil gallery plug from the rear oil pump or filter housing?
I did find a picture of the timing gear cover that shows this opening but I'm not sure how is should be sealed or plugged.
Thanks
Thanks
