- Fri Feb 24, 2012 10:31 am
#88
I intend using a 1959 Redditch outer primary cover with the Indian inner case. I have thought the only real problem to solve here is that the Indian primary is filled through a hole in the outer cover and the UK primary is filled through a hole in the inner case, therefore I will have no way to put oil in it. Short of converting to belt drive, I feel the best way is to drill and tap a hole in the top of the inner case. If anyone has done this, two questions......
1) At what place on the inner case should the filling hole be located, where was it on the Redditch case?
2) is there enough thickness in this area to drill and tap a hole for the threaded plug?
I had a look at the online parts book, but the illustration does not show the relevent detail!
