- Tue Feb 07, 2012 9:36 pm
#9380
Hi Matt - The fill up quantity of OO grease is 700 grams so you shoud have enough. I assembled my box 'dry' and added the grease by warming it up to a liquid. However if you use this method don't use a plastic funnel as you'll melt it! On the plus side you'll be able to use the level plug to get the right quantity in there.
I see you're going to buy a manual to re-assemble your box. That's fine but just bear in mind that it says 're-assembly is the reverse of dismantling', but a whole chunk is missing from the dismantling procedure. However if you've got this far I'm sure you'll be fine. The manual does give some good tips on making sure everything is OK.
Good luck!
Tony R
Good luck!
Tony R
