Airflow fairing
Posted: Sun Nov 04, 2018 11:38 pm
by David S.
Hi - I'm about to start restoration of my Airflow Super Meteor Minor Delux. When I got the bike it had no fairing and the front mudguard was damaged. I need info on how the mudguard was fitted to the bike - mine was fitted using some spacers to the bottom fork brace but was quite flimsy - I can't seem to find any drawings of the fittings. Can anyone help? also fittings for the fairing.
Cheers
Dave
Airflow fairing
Posted: Tue Nov 06, 2018 5:51 pm
by enfield49
There is a fairly flimsy piece of angle iron attached to the pinch bolts,. If you have the original fork stem you will find the bottom plugged , there is a threaded hole in this plug which takes a bolt which is passed through the mudguard with suitable large washers and stiffens the assembly. For the fairing you need an alloy casting from the headstock and extended engine mounting bolts. \\\\graham
Airflow fairing
Posted: Tue Nov 06, 2018 6:41 pm
by David S.
Thanks Graham,I have the angle iron but didn't know where it attached - it is the original fork stem so I will check for the hole.
Airflow fairing
Posted: Tue Nov 06, 2018 7:40 pm
by Scalyback
[center]
Is it a Super Meteor (700cc) or a Meteor Minor De Luxe (500cc)?
The fitting is probably the same in either case, click on the following link, scroll down to Kevin's Corner and below that is a pdf of the airflow fitting instructions. Hopefully, that will help...
[center]
REOC 15084
Tabellarius de verbis. Ostensor gaudium[/center]
Re: Airflow fairing
Posted: Wed May 06, 2020 3:37 pm
by Hercules
Hi , Can you once again share the fitting instruction PDF and photos. Because, looks that link is expired in tiny pic.
Thanks in advance,
Selvam
