oil leaking from gearbox drain
Posted: Thu Oct 04, 2018 7:06 am
I did the first oil change since owning my enfield for a little less than a year the other day since I have probably done 2000 miles on it by now, I should really have done it alot sooner but I have been busy as well as wanting to ride it rather than working on it. Anyway it was easy enough and I drained the oil and replaced with Comma 20w50 mineral oil. I made couple of observations, the oil was pretty dirty but there were no signs of metal whatsoever which was good, it looked a little milky in places, especially when I tipped the bike over to get the last dregs out of the quill bolt opening. I have had a cork quill bolt seal soaking in a jar of above oil for a few months now along with a filter element, but my quill oil feed did not have a cork, it has a rubber thing on it not too unlike a valve stem seal to look at. It looked a bit hardened with age but I left it as it was as it looked better than a cork but maybe I should replace that. The parts book shows my bike 1991 iron barrel should have a cork and not a rubber seal.
The other thing I tried to do is seal an annoying seap of gearbox oil from the drain plug on the gearbox. When I bought the bike there was a white nylon washer on there and it leaked a bit. I replaced with a fibre washer from our hosts and it leaked more. In desperation I tried a big rubber tap washer thing but it distorted when doing the bolt up but slowed down the seeping. I just fitted a brand new sump plug from our hosts and a dowty washer and low and behold I still have a drip on the drain plug and a patch on the garage floor. I am thinking do they do metal washers that have thick say 3mm rubber side bonded to the metal? I think the bottom of the gearbox drain hole is finished badly and wont make a seal with a normal washer. I am looking for a fix that wont involve taking off the gearbox for now and addressing that. Maybe I could use a thick rubber washer with a metal washer on top?
Now that I have done it once it will be easy to do my oil on a more regular basis.
