Reg-rec problem? Advice appreciated.
Posted: Thu Sep 27, 2018 9:11 am
(Also posted in Midland Bullets, so if you've already read it there, please ignore).
Sadly, my Meteor Minor came to a full stop yesterday (in about the remotest spot it could find). I suspect the (New!) regulator rectifier, but here are the symptoms; I'd appreciate any thoughts.
For several miles the ammeter needle had been flicking widly back and forth, mainly when running at speed, and from time to time it remained on the maximum positive current. Then the engine died. I could get a rather weak spark at first, the points were opening and closing, and petrol was getting through. The ammeter didn't register any charging current with the points closed. Then the electrics gave up altogether -- no lights, horn, etc. The negative battern terminal (positive earth system) showed evidence of heat, and the battery was rather warm. The AA man found 4.5v at the battery (6v system) but couldn't get it to accept any charge.
