- Fri Sep 14, 2018 3:19 pm
#8809
I've got a Mikcarb on my '06 Bullet 500. It looks like it has two stubs with provisions for tubing. I'd assume one is an overflow that should drain somewhere behind the swingarm and into the ground, and the other went to the original air filter box (which has since been replaced with a conical filter). What do those of you that have fitted a conical or pancake air filter do with that particular hose? Do you stub it off? Leave it open?
