By marco voorhorst
#8786
Hi there!
I ride a Bullet 1951 and have a little problem.
When the bike is Colt, no problem. But after let say 12 km the clutch is beginming to slip.
First a bit. But after 20 km more. (In 3, and 4 gear).
The nexst day it starts all over again.
The clutch plates looks good to me.
What van I do. Buy new plates or....?
#78860
I would start by fitting new plates. I have found that it takes what seems like very little measurable wear before the plates start to slip. And use ATF (Automatic Transmission Fluid) in the chaincase. Get Type F if you can.
By marco voorhorst
#78876
The cable free play is there! That's niet the problem. But thanks anyway.
Type of the oil is maybe the problem. I use sae 50.
I try thinner oil as you say! Thanks.
By simon
#78975
Does it have the 6 springs or have you only got 3? I had a 51 and it was sold to me without the additional spring mounting that hold the additional three springs.
By ric
#78979
The cable adjuster adjusts the cable, the clutch adjuster adjusts the clutch.
You can have a lot of cable slack but the clutch will still slip if the clutch adjuster has none.
