- Thu Aug 02, 2018 5:00 pm
#8712
Good afternoon everyone,
Hopefully this will be a simple question for some. Please be patient & understanding, I’m neither a mechanic or an auto electrician, so the issue I have has left me slightly stressed & probably at the point where I can’t see the wood for the trees if that makes sense.
I’ve been putting my Enfield back together this last day or so. I had to strip the front end to replace the headstock bearing & attend to a few other issues.
Now when I stripped it down, it all looked very straight forward & simple to put back together, but, as with most good plans, I got dragged away from it & it’s been over a year since I started. Consequently, that simple wiring setup now just looks like a plateful of spaghetti.
I’ve managed to get all the bits back up & running with the exception of the headlamp.
I have two, possibly three plugs spare that will fit the plug on the headlamp assembly. The obvious choice is a plug that fits perfectly & the wire colours match. However, when I plug this in, it does not operate the main bulb.
One of the other plugs does, but main beam on permanently (whether the lights are switched on or not).
I am not sure what electrical system I have on my bike so trying to refer to any wiring diagrams for a bundle of wires all taped together is very difficult.
The bike is a 500 cafe racer & from the pictures I received with the bike, I believe it may have started life as a 2003 ‘Sixty 5’. Electric start with points, not EI.
Does anyone know if this system needs the engine running for the headlights to work? It’s been so long since I rode it I really can’t remember!
That’s the only thing I haven’t done yet is run the bike up. I also had to repair a badly welded tank & horrendously fitted fuel cap, so I need to be 100% sure that I’m ready before I pour fuel in.
My concern with starting it up is that if I do have the wrong plug in that headlight, could I cause any damage (other than blowing the bulb) if I have it wrong?
Any help or advice would be gratefully appreciated......
Regards,
Andy.
Regards,
Andy.
