- Thu Jul 26, 2018 4:29 pm
#8690
2004 Bullet sixty5. 5 speed ES.
Not had it long, no problems so far (apart from water in the points after a wash).
I find that if the clutch cable is properly adjusted I can find neutral while stationary without a problem. I adjust it with the engine cold so there is just a very little free play in the cable and its fine.
But when the engine warms up the free play increases and clutch drag stops me finding neutral when stopped. If I keep it adjusted (while travelling) using the adjustment on the lever it's fine.
When the engine cools down again it's too tight and I have to slacken it off to get free play.
I am guessing that the alloy gearbox is expanding more than the steel pushrod and causing this.
Is this common? Has anyone else noticed it?
Current Bikes
2020 Himalayan
1984 BMW R65LS
2020 Himalayan
1984 BMW R65LS
