Carb blowing out fuel
Posted: Tue Jun 19, 2018 8:41 am
by calv
My monobloc seems to be blowing out fuel into air filter and bike won't start. Got electronic ignition now. Valves and heads all good. Timing marks all good. Any ideas would be great
Posted: Tue Jun 19, 2018 10:03 am
by stinkwheel
Could the ignition timing be 360 degree out?
Posted: Tue Jun 19, 2018 10:07 am
by calv
Checked all that
Posted: Tue Jun 19, 2018 10:48 am
Calvin, that is a classic symptom of incorrect valve timing.
Posted: Tue Jun 19, 2018 11:23 am
by calv
Hi Mark. I'm suspecting that but all the timing marks are still lined up . I tried physically to slip the timing change but would not budge. Cams rockers all seem to be moving in time and sync.
Posted: Tue Jun 19, 2018 11:48 am
One other possibility is inlet tappets too tight?
Posted: Tue Jun 19, 2018 11:52 am
by calv
They spinning freely at Tdc
Posted: Tue Jun 19, 2018 11:54 am
by calv
Going to check carb one last time to see again if any blockages even though I'm 99.9 % it's clear
Posted: Tue Jun 19, 2018 12:31 pm
by Bullet Whisperer
Hi Calv, it would be worth checking the 'other tdc', rather than the firing one and see if the inlet valve is just opening and the exhaust valve is just closing by roughly the same, small amounts around tdc. If not, the valve timing is out. Regards, Paul.
Posted: Fri Jun 22, 2018 10:24 pm
Those electronic ignitions are difficult to get dialed in properly. Are you sure the ignition timing is correct?
