Missing issue with Amal and Sr magneto
Posted: Wed Jun 06, 2018 11:18 am
by Hercules
Hi All, I have 1959 Royal Enfield 350cc. Recently I have installed SR1 Magneto with ATD to my Bullet . It is working good with Mikuni carburettor. But when I put my AMAL 376 monobloc, I’m getting missing issue.
And also Amal was working good with Delco point ignition .
Missing happens with Amal and Sr combination. Any idea why it is happening .
Thanks in advance ,
Selvam
Posted: Wed Jun 06, 2018 2:10 pm
by Hercules
Also fuel is rich and plug gets burn out. We have already tried adjusting the Air screw .
Posted: Wed Jun 06, 2018 2:18 pm
I think when Hercules says Delco he means distributor. I believe this is a term used in India? Just for clarification.
Posted: Wed Jun 06, 2018 2:37 pm
by Hercules
HI Mark,
Exactly you are correct. It is distributor.
Posted: Wed Jun 06, 2018 3:12 pm
This is quite a puzzle! Can you list the jets of the Amal carburettor that is fitted? Main and pilot jet and throttle slide if you can please. I'm wondering if the Amal is jetted too rich and the old distributor was timed wrongly? And perhaps you could explain exactly what the missing problem is, at tickover, half throttle, full throttle?
Posted: Wed Jun 06, 2018 5:46 pm
by Hercules
Mark, thanks for your reply. Here is the details.
Bore 1:00" (25.40mm) diameter, Main Jet size 180, Slide number 4, Needle jet size 106, Pilot jet size 30 and Needle type C (Part# 376/063 - 95mm long)
It is tick over sound. When we start the vehicle and leave in idling it misfire and producing tick over. And also, while riding with half or full throttle it misfire and off.
Is there any timing settings or point settings needs to be done with this SR Magneto and Amal combination.
Thanks
Posted: Wed Jun 06, 2018 6:49 pm
by Exile
"It is working good with Mikuni carburettor...."
There's the answer then.... bin the Amal.
Posted: Wed Jun 06, 2018 9:57 pm
The Amal carb you have is actually slightly smaller than the one originally specified (which was 1 & 1/16") and your main jet is also slightly smaller (190 originally) so the richness is odd. The valve and ignition timing should be the same for any carb as they are elements of the overall design taking into account valve lift, compression ratio, piston stroke and bore etc. Is it possible that you have mis-timed the magneto? The advance retard unit is usually set in the full advance position for timing, did you do this? I still don't see why the Micarb works though!
Posted: Thu Jun 07, 2018 6:32 am
by Bullet Whisperer
Quote: There's the answer then.... bin the Amal. For anyone wishing to do so, there is a large bin at the end of my lane, feel free ...
Posted: Thu Jun 07, 2018 11:45 am
by Revband
And I will happily pay the postage to save going to Paul's bin.
