Squeal
Posted: Tue May 29, 2018 7:50 am
by Jamesy
After a ride there is a squeal coming from the back wheel of my b350.Its only after a ride and disappears when it's cold.I have just replaced the wheel bearings convinced it was them.I stripped it down and can't see the obvious and am not convinced it's the hub bearing.Anyone had this?
Squeal
Posted: Tue May 29, 2018 9:34 am
by Exile
Never experienced that. Could it be a brake liner? Lack of lube?
Squeal
Posted: Tue May 29, 2018 11:12 am
by Jamesy
The drum/ shoe plate on the left is showing rubbing wear against the sprocket assy on the right.When I tighten up the nut on the drum plate it is solid against the sprocket.The bearing/set up in the 38t sprocket looks nothing like the hosts parts manual.
Squeal
Posted: Tue May 29, 2018 11:15 am
by Jamesy
When I say solid against the sprocket I meant the sprocket doesn't turn freely
Squeal
Posted: Tue May 29, 2018 11:41 am
by vince
Hi, do you have the spacer 141115 which fits between the bearing and brake plate? Vince
Squeal
Posted: Tue May 29, 2018 6:54 pm
by Jamesy
Spot on Vince it's missing and have ordered one.The distance collar item 12 part 141130 Is that on the inside of the rear brake plate.The parts diagram looks like it's on the outside.
Squeal
Posted: Tue May 29, 2018 8:19 pm
by vince
Hi, despite the drawing it fits between the bearing and the brakeplate, the oilseal fits around it. Vince
