Page 1 of 3
Amal Monobloc Why?
Posted: Thu Jul 19, 2012 5:51 pm
by Craig
Question for you Experts!
I have Acquired a Thunderbird 350 AVL with a AMAL Monobloc Carb on it (I all So own a Std 350) Now in Lay Mens Terms : Q: "What Use or Benefit do's The Carb give me for day to Day Normal use??"....Q: "Would I Be better Of Sticking on an old Micarb & Plodding on??"
.......Thanks For any advice...Its a Loverly looking classic Carb but do i need the hassle of Ticking and air Play when with the micarb on My Iron 350 i Just Lift & go!!..... Thanks All..
Amal Monobloc Why?
Posted: Thu Jul 19, 2012 6:07 pm
by Bullet Whisperer
Hi Craig,
I think the Monobloc carbs are among the best you can use on a Bullet, they give a wide range of settings with the various jets, slides etc and have five needle grooves to help with fine tuning. Conversely, all of these can cause their own problems if the settings are incorrect. The Micarb is a good, simple carb and easy to work on and maintain, but a bit small if you want the best performance from your machine.
Paul.
Amal Monobloc Why?
Posted: Thu Jul 19, 2012 6:25 pm
by Craig
Ah "Thanks Ho bullet Master".......
What I am After is a Reliable Day to Day Bike (Like My VM24 Carb equipped 1999 350 Std,Iron head )only a Tad faster & Better MPG.... An AK47 Not an M16 "If Ya Know what I Mean?".....
Q: Will a VM24 work ok on a 350 AVL or Back to Origanal CV Carb?.... Thanks for you in Put !...Cheers Craig
Amal Monobloc Why?
Posted: Thu Jul 19, 2012 6:50 pm
by Bullet Whisperer
Hi Craig,
If you have a VM24 to hand, why not stick it on and give it a try?
Paul.
Amal Monobloc Why?
Posted: Thu Jul 19, 2012 7:06 pm
by Craig
I Intend to try my Old Pea Shooter Silencer 1st then and My old 24 Carb then (Hope fully this weekend) or as soon as it stops raining (2018 then)... ;0).....But No Negitive thoughts on the Micarb then!..Thanks...
Cheers all... Craig (And Thanks BW, if i go the tuned Monoblock Route..Ill be Back)....
Amal Monobloc Why?
Posted: Fri Jul 20, 2012 5:56 am
by grunda 12
imho the monoblock is a nice luxury although a mikcarb can equally be tuned if desired but the monoblok has the bling factor and looks period atb g12
Amal Monobloc Why?
Posted: Fri Jul 20, 2012 6:41 am
by Edward
Any performance gain from the Monobloc is due to its larger choke area. This gain is only manifested at high revs and large throttle openings which may be something you don't want to do too often. The smaller Micarb will allow faster gas speed,better atomisation and much of the time better performance. I would say the Monobloc is a complete waste of money unless you were using the upper reaches of the engines performance habitually (there are better carbs for that job too)and with a standard bottom end disaster is the likely result.
Amal Monobloc Why?
Posted: Fri Jul 20, 2012 8:41 am
by Bullet Whisperer
For the record, the Monobloc carbs were made in three body sizes - 375, 376 and 389. The smallest 375 was 7/8" choke diameter, smaller than the VM24 Micarb. The three sizes overlapped each other on choke size and the biggest was a 389 in a 1 3/16" choke size. Choose the right one and you will see an all round improvement in performance, as well as having the 'bling factor' if that's your thing. The only downside with the Monoblocs is they never made bigger ones. Best modern carb for me would be the Amal MK II, but each to their own.
Paul.
Amal Monobloc Why?
Posted: Fri Jul 20, 2012 8:57 am
by Les H
No difference at all performance wise if size of each is equivalent. Full bore = One hole....one needle that restricts air flow...as long as mixture strength is set correctly (main jet)= no difference....main differences......Cold start....Amal= choke slide that restricts air....Micarb= opens extra starting jet....Float bowl....Monobloc= on one side.....Micarb= concentric (same as Amal Concentric) Fitting.....Amal= flange O ring= Solid secure....Micarb= Rubber sleeve...can blow off & can be difficult to match to inlet tract..... Wear rate......Amal= zinc slide (now make brass at extra cost)...Micarb=brass....Looks.....you choose...(most prefer Amal)......Reliability....Amal=leaks etc.....Micarb= Excellent no leaks...... VFM= Micarb....Winner= Micarb.
Amal Monobloc Why?
Posted: Fri Jul 20, 2012 9:00 am
by Les H
OOOOOPS....NOTE: I posted before Paul's post above was showing...I'm not trying to be different to Pauls views...just an accident of overlapping posts....best wishes to the "Whisperer".
