- Sun May 13, 2018 9:17 pm
#76762
I'm guessing here that you're after a 21" front wheel in this case. If so, don't forget that it will affect the speedo readings. The Electra-X speedo is calibrated for a 19" front wheel with a 2:1 speedo drive. It is possible to move the speedo drive to the back wheel where it would originally have been. It only needs a couple of slots cutting in the hub to match what's on the front wheel and the outer rear spindle spacer thinning down by the thickness of the speedo drive casting (I'd assume you'd use a metal one rather than the plastic effort the Electra-X uses), along with a longer speedo cable, say 66". If our hosts don't stock these for the Indian speedometers, ebay has some.
I have done this with one of my bikes and it works fine.
