Folding Kickstart
Posted: Wed May 09, 2018 4:52 pm
by Aethelric
I find the standard top folding kickstart a little awkward. It stops me putting my foot comfortably on the footrest.
Has anyone tried the bottom folding kickstart Part No 570242 from our hosts. It looks like it leave a bit more room for my right leg.
Folding Kickstart
Posted: Thu May 10, 2018 5:31 am
by burcotbullet
Not tried it myself but would be interested to hear peoples feedback as i have the same issue, may be something to do with size 12 feet !!
Folding Kickstart
Posted: Thu May 10, 2018 5:48 am
by papasmurf
When I asked out hosts about it the folding kickstart it is only for certain models as it is not strong enough for other models.
Folding Kickstart
Posted: Thu May 10, 2018 5:51 am
by papasmurf
From the parts book:-
This kickstart folds at the bottom which allows it to fold neatly out of the way. Fits 4 or 5 speed (none EFI models) and Electra EFI models only.
BOLT NEEDS MODIFICATION FOR NON - EFI MODELS (before E5: U5S5F0AB003637 G5: U5S5F0AB003654 19/02/10)
Folding Kickstart
Posted: Thu May 10, 2018 9:39 am
by Leon Novello
Just move it back one notch on the spline, problem solved.
Folding Kickstart
Posted: Thu May 10, 2018 10:06 am
by Beezabryan
Do as Leon has said, it is a cheap fix :)
Folding Kickstart
Posted: Fri May 18, 2018 10:57 pm
by Aethelric
Leon was right. It's a better solution. Wish I'd read it before I bought a folding one. Oh well.
Folding Kickstart
Posted: Tue Jun 12, 2018 9:28 pm
by Aethelric
Update
Even moving the kickstart back a bit on the splines I found it better but not perfect. So I fitted the bottom folding kickstart. I actually mounted it a couple of spline forward.
I find it much better. It's out of the way when I'm riding and can get a longer swing on it to start the bike so the bike starts on the kickstart more reliably.
I did have to take a grinding wheel to put a groove on the bold before it would fit.
It's a definite improvement.
Folding Kickstart
Posted: Wed Jun 13, 2018 10:28 am
by mauri
had this kickstart for a while, and yes it does liberates the space for your boot.
only problem is that its more of a novelty kickstart(dont forget that is was made for the efi's with electric start), because it bends badly.
and will keep on bending till its useless.
i have tried hardening it but its steel is just to mild to start with.
the kick start of a XT500 or a cb750 works better, depending on the type of exhaust you have.
Folding Kickstart
Posted: Wed Jun 13, 2018 12:10 pm
by Aethelric
Thanks Mauri
Papasmurf mentioned above that he had been told the kickstart was not strong enough. Strange because it looks more solid than the original but I guess it's due to the materials. I'll keep an eye on it.
