Connie Concentric carb question
Posted: Wed May 09, 2018 2:27 pm
Ok, I know a single carbed Connie should have a Monobloc fitted, however the one I had was shot, so on went a "premier" Concentric. The monobloc would have had a 3.5 slide, 300 main jet, needle position 2.
On the concentric I have fitted a 3.5 slide, the main jet is a 210.
The bike (oh did I ever have issues with it) is running reasonably well, HOWEVER when accelerating (racing between roundabouts) the engine bogs down a bit, the engine response (power) improves if I back the throttle of slightly. I could do with a little guidance in the right direction...seems the older I get the more things I forget? Which reminds me: I fitted a bellmouth with a tea strainer/gauze and some foam to it to stop crap getting sucked in, bad/good idea?
Hope you can point me in the right direction, thanks
