Excellent result with Improved vm28 carburettor slide from Hitchcocks
Posted: Tue May 08, 2018 6:03 pm
by NicoV
I installed the improved carburettor slide from our host plus a larger idle jet. The Bullet now runs much, much better especially at colder temperatures.
I live on a moderate height (450m) in central Norway where the air is always quite cool in the morning. Even in summer, the morning temperature is often less than 12 degrees. When driving at 75kmh the air reaching the cooling fins is much colder.
Before I nearly always had to have the choke on for 10 km in the morning. Now 1 km is enough, and the Bullet mostly starts from the first kick.
Posted: Tue May 08, 2018 7:33 pm
by Jamesy
Check the spark plug colour for the truth.My 350 after rejetting and maintenance was kicking first/second time and running as sweet as a nut.Spark plug colour''' white.Ongoing adjustment.
Posted: Wed May 09, 2018 10:53 am
by Martyn s
Hi why are these slides better than the originals?
Posted: Wed May 09, 2018 12:37 pm
by NicoV
You can see the difference in the catalog. They give a somewhat richer mixture than the standard slide.
Posted: Sun May 13, 2018 2:20 pm
by NicoV
@Jamesy: I checked the spark plug. It has the right colour. Before it was always white.
