- Mon Apr 16, 2018 1:34 am
#75965
Hi Guys-----Hi Jamesy..The "Flick" of the Ammeter needle occurs when the points open and the spark is generated..........However, a full electronic system ( ie NOT the Transistor Assisted Circuit which still makes use of the points ) .. uses a rotating magnet passing a coil of wire to induce an electric current within that coil and so create the spark..........Depending on how sensitive your type is you might get a flicker but it won't be so well defined as the points type....................Also, your single cylinder machine might have the type with TWO coils and TWO magnets ( mainly used for twins OR 4-cyls. )..... In this case if both coils are being used then you might get 2 flicks showing........What's happening here is a system known as the "Wasted Spark" where 1 spark occurs at the Compression stroke and the other at 180 degrees later on the Exhaust stroke........From a mechanical point of view this is better as the two rotating magnets counter-balance each other......The spark happening in the Exhaust does nothing, hence the term "Wasted Spark"..............I have this on my Bullet '65.
Hi Stinkwheel.......yes, what you say is quite true but that's only half the story.......Consider this}----With the piston now just past TDC and about to descend on the Power Stroke we are asking the momentum within the flywheels to carry the whole crankshaft assembly through that Power Stroke...back up through the Exhaust Stroke.....down through the Induction Stroke...back up through the Compression Stroke( with the de-compressor valve now shut) and get the engine started.....That's a BIG ASK for your leg muscles to achieve....The second half of the story is having got the piston over TDC as you described, we now need to get it just past the other TDC and about to descend on the Exhaust stroke........This now Halves the amount of momentum needed before ignition point is reached or if you like it Doubles the amount of energy available to take the piston through the compression stage.......It takes a bit of trial and error but it's worth it in the long run....Good for your bike, good for your leg muscles, maintains your Street Cred. in front of your mates etc.............For a bog standard Bullet running on 6:1 CR it probably doesn't matter but it certainly makes starting easier on a 10:1 pepped-up long stroke beastie !!
