WD/CO clutch
Posted: Thu Apr 12, 2018 9:30 am
Hi, just giving my WD/CO aa few test rides to bed it all in and the biggest problem so far (other than the inadequate front brake!) is the dragging clutch making gear selection and finding neutral difficult.
I believe this clutch design is used across the range and for many years but as the plates etc are all in good useable condition and the springs are new how can I set it up to work better?
The gearbox also drops oil and a fellow Model G rider says to use Spherol grease in the box. Fair enough, but how do you get it in there?
Thanks.
Thanks.
