By tribonnie
#8189
Hello, anyone used the “oxyturbo” the kits for brazing, want to fabricate and braze brackets etc onto motorcycle frames. Thanks Richard
#74932
I used to use something similar to braze refrigerator pipework. I'm not sure those little kits would produce enough heat to braze a bke frame. Temperature would more than enough but not enough heat imo.
#74933
Hi guys-------- yes, I agree with PeteF........I currently operate an Oxy-Acetylene outfit and have done so continuously since I first qualified during the 1960's..... It's not so much the temperature achieved but more about the Quantity of heat required to do the job in hand..........Have a look at the short video within this link and you'll see what I mean---- All the examples are of thin, sheet metal whereas your typical bike frame will be much thicker AND of greater volume.......It's not only getting the combined workpiece up to temperature but maintaining that "Background" heat whilst you do the actual brazing that eats up the gas and those disposable canisters just don't have the capacity............ https://weldingsuperstore.co.uk/brand-oxyturbo.html ..... ...MiG welding might be better as only localised heat is produced but in either case this is not a job for the inexperienced.....If I were you I'd take it along to a professional Welder for peace-of-mind..
