Model G Headlight
Posted: Wed Mar 14, 2018 9:40 pm
by Hardhat_Barry
Is this the right headlight for a model G I seem to have a large mouth type hole at the bottom (picture is rotated 90 degrees)?
Model G Headlight
Posted: Wed Mar 14, 2018 10:51 pm
That's the hole for an under-slung pilot light used in some 1950's bikes.
Have a look at the parts book page here:
http://www.hitchcocksmotorcycles.com/pa ... ucas_Lamps
Model G Headlight
Posted: Thu Mar 15, 2018 8:50 am
Barry, when posting questions about originality it helps a lot if you say what year the bike is. The Model G ran for a long time, 1946 to 1957 in various different guises and the specification changed a lot over those years, not considering all the bits fitted by Previous Owners (the Americans just call them POs!) That underslung pilot light type of headlight was fitted to a lot of early 50s bikes.
Model G Headlight
Posted: Thu Mar 15, 2018 1:01 pm
by Hardhat_Barry
Hi Adrian
Is the pilot light like this one?
Model G Headlight
by Hardhat_Barry
Model G Headlight
Posted: Thu Mar 15, 2018 3:02 pm
It looks the right shape.
Scalyback, if you're reading this, does Barry's ebay item match what's in your old Lucas catalogues?
Model G Headlight
Posted: Thu Mar 15, 2018 4:02 pm
That Ebay one is different, it has a rubber grommet to mount it on a flat surface. You need the type that is a lens to go inside the cast alloy cowl that is fixed to the bottom of the headlight. It also has a fixing clip that sits behind it. There should also be a rubber seal to go round the edge but you could use black silicone sealant for that. I might have one somewhere...
Model G Headlight
Posted: Thu Mar 15, 2018 5:08 pm
by Hardhat_Barry
Hi Mark,
If you do find you have one and are willing to part with it let me know.
Is it worth me putting a wanted ad in anyway in the buy/sell bit of the forum (I feel I'm going to put a lot of wanted for this Model G)?
Model G Headlight
Posted: Thu Mar 15, 2018 7:43 pm
Barry, I've had a quick look and can't find it but I will keep looking.
Model G Headlight
Posted: Thu Mar 15, 2018 8:03 pm
by Hardhat_Barry
Hi Mark,
Thanks for looking.
Is this the one?
https://www.ebay.co.uk/itm/NOS-Lucas-Pi ... 2796004211
Just in case you cant find it.
