- Mon Feb 26, 2018 10:15 am
#74388
Adrian, You are absolutely correct, I was trying to establish that putting a capacitor in parallel with the battery will do nothing to make the bike start better, it is only needed if the battery is removed.
Valsp, Not only the Interceptor, many sports bikes of the era had a capacitor fitted, but perhaps not for the reason you think?, back then there were a lot of sports bikes used for daily transport and then raced on a weekend, the capacitor was fitted to enable the bike to be ridden to the race meeting the battery and any other unnecessary parts removed the days racing completed, parts refitted and the bike ridden home, Triumph even had a plug in headlight assembly for the same reason.
The capacitor is needed to smooth the voltage peaks from the alternator as these peaks can be of a high enough voltage to destroy the regulator/rectifier.
Rescind my remark re bad advice?, no definitely not as bad advice was being given.
