1961 500 sports Twin Rocker spindle
Posted: Wed Feb 21, 2018 2:09 am
by Peter D
Hello All, I have been checking and cleaning the rocker assemblies. All went smoothly until the last one. At some time in the past a spindle has been put in the wrong way around. So I cannot screw a threaded bolt in to draw it out. I don't think it will make any difference to the operation, but it is not right!!! Has anyone run in to this sort of issue, and how to get the spindle out? It does not seem possible to tap it out from the other end for fear of damaging threads.
Peter D
Posted: Wed Feb 21, 2018 6:32 am
by vince
Hi, I bought a new set of spindles from gander and gray in the 70s none of which were threaded. Perhaps yours is one of these. Vince
Posted: Thu Feb 22, 2018 12:23 am
by Peter D
Hi Vince,
mine are all threaded including the one which in the wrong was around, but how do I get it out, or don't I?
Posted: Thu Feb 22, 2018 7:57 am
by Bullet Whisperer
Hi Peter,
I have two methods I use on both twins and Big Heads to get the spindles out with ease, first is a 'Car Ariel' magnet of suitable diameter to pick up the end of the spindle and pull it out, or second, if a bit more force is required, a 'Phillips' type screwdriver of a suitable diameter can be slid right inside the bore of the spindle, pulled over one way so it 'grabs' the spindle and pulled out. Slacking the tappet adjusters will help a bit, too. Regards, Paul.
Posted: Sat Feb 24, 2018 5:12 am
by Peter D
Thanks Paul, I'll give it a try, and let you know how I get on.
Cheers, Peter
