By martyn15
#8061
Hi does anybody know if Indian bullet forks / yokes will fit a 60's Crusader Sports frame? Im building a cheap trials bike thanks in adv
#73972
Yes they will. Bullet yokes are the same spacing and length as Crusader fittings. There are some detailed differences to do with the top yoke filler plugs but if you are using Bullet length/type stanchions you will be ok. REgards, Mark
Just be aware that the Indian factory changed the steering stop design around 2002/3(?), so later bottom yokes will need older-style steering stops welding on in place of the steering lock tang. The older style looks like this:
https://www.ebay.co.uk/itm/Brand-New-Ro ... SwNuxXbOFK
The later design looks like this:
http://www.ebay.co.uk/itm/NEW-ROYAL-ENF ... wTL4wUIOGg
The Superstar or early Lightning variants of the Indian Bullet had plain fork yokes which would be ideal, unless you want an alloy top yoke or casquette.
By martyn15
#74006
good point and thanks for the links. dont know what it will steer like in observed trials- any body tried Indian bullet forks on a trials bike?
