If it's not one thing!
Posted: Wed Jul 11, 2012 9:39 am
As per the past thread, had the bullet back together and running well, re-torqued the head and 'heath Robinson-ed' the air box assembly using inner tube till the new box to carb rubber arrives, still no sign of the mysterious disappearing old one.
Fired it up yesterday, initially ok, suddenly only runs in coke and then starts cutting out, sounds like revs picking up before it stalls suggesting leaning out soI'm guessing a fuel feed prob.
Drained the tank, stripped and cleaned the tap which seems ok though doesn't seem to be flowingV quickly, about 250ml per minute! Does anyone know what the flow rate should be?
Carb off later and check to see if all ok, it was spotless when it went back on so, not sure. Annoying stuff.
