Higher handlebars for a C5
Posted: Thu Dec 14, 2017 6:56 am
by Toecutter
I would like to fit a taller handlebar on my C5, can any one suggest an option using the standard cables. Thanks.
Posted: Thu Dec 14, 2017 9:36 am
Hello there----have a look on page 103 of our hosts catalogue..........I have item No.93051 fitted on my 500cc Bullet '65....
Posted: Thu Dec 14, 2017 9:42 am
Mr. GT the cat is my test rider !!----------The bars will fit on directly with no need to alter any cables etc...The bike actually handles much better IMHO and you'll have a more upright riding position compared to the standard bars so less loading on the small of your back........I'm 68 and appreciate that improvement very much !!
Posted: Thu Dec 14, 2017 2:07 pm
by Wayne
Toecutter - please not that your bike and the one featured in the last reply are entirely different.
Posted: Thu Dec 14, 2017 3:30 pm
Hi Guys-----how's the shop Wayne ??---Re}--My last rely, yes the bikes as a whole is different but from what I've seen the handlebar clamping is still the same......I did make it clear that mine was a Bullet '65 and so not the C5 that our friend owns..........here's a top view of a 2015 C5 -----> ----->
Posted: Thu Dec 14, 2017 5:29 pm
by AndyMc
Hi I have a C5 and I suspect you could raise the bars without altering the clutch and throttle cables but you would need a longer brake line. I was going to fit risers to mine but I have replaced by brake line with braided hose and don't really want to shell out again for another longer one so have left as is.
Posted: Thu Dec 14, 2017 9:22 pm
Hi Guys----Hi Andy,... Some years ago now I fitted a complete disc brake conversion to my previous Bullet '65 using items taken directly ( Legally !! ) from a working bike in India supplied by some bloke called Henry down in Gloucester way....( No names--no "Pack Drill" eh ?? )....The calliper, flexi-hose and master cylinder units were still assembled as one and went straight onto my Bullet '65 which had already been fitted with those bars I mentioned.......Now I don't have any direct experiences with a C5 as yet but I'd wager my Aunt Fanny's left toe nail that those bars will be OK............Maybe Mr.H. will let you have a set on a "Sale-or-Return" basis ??
Posted: Fri Dec 15, 2017 5:27 pm
by Toecutter
Thanks for all your responses. I fitted today the Hitchcocks Braced bars, 91/371. I removed the seat and tank to reclip all the cables. I did not have to change any of the original cables, although I do have an after market stainless brake line fitted. The only tricky part was drilling two holes in the bars to secure the plastic pins on each switch cluster. I still need to get a replacement left hand grip has I had to cut off the original one. I have a photo but don't know how to add it to the reply.
Posted: Fri Dec 15, 2017 7:12 pm
Sorry Toecutter----I'd forgotten about those two stubs you mentioned.....They stop the grip etc from rotating in an emergency....I've actually fitted the other, alternative bars from Mr. H ( Item No. 93051 ) which are a bit more straighter but give the same lift...... To post a photo use these folk}----
https://imgbb.com/ ...
