- Wed Nov 22, 2017 11:57 am
#7903
Hi,
I am new to this forum, so a big thank you to Hitchcocks and whoever is involved with the forum.
I am working on what I have been told is a 1993 500 Bullet.
It had huge wet sumping issues, so I decided to start with the obvious (i.e. breather, worm drive seal and timing shaft seal).
The worm drive seal had definitely perished so that will be replaced with a bonded in seal worm drive.
I then took off the timing pinion to find that that seal too needed to be replaced. What I thought would be a simple replacement has proved a problem in that the standard 20mm ID x 30mm OD x 7mm W seal has too large an outside diameter to fit inside the machining on the crankcase.
On closer inspection it would appear that originally a rubber seal was not used and a steel cup has been machined and pressed into the crankcase to house an oil seal.
My problem is as follows:
1) I do not no the measurements of the seal that I took out as I had to mangle it to get it out.
2) I measure the required seal should be 20mm ID x 27.5mm OD x 7 or 8mm width. However, the two closest seals are 20 x 27 x 5 or 20 x 28 x 7.
So, my questions are has anyone out there seen this conversion before (i.e. is it some form of standard conversion) and two what might the required seal be?
I am hoping that the 20x28x7 fits, but I suppose next best is the 20x27x5 and hope the seal is man enough.
Hope someone out there can help.
Regards
Pat
Regards
Pat
