- Wed Oct 25, 2017 3:08 pm
#7809
Hi, I felt this problem on my bullet 350,year 2008 : In deceleration, the engine does not immediately fall to the idle , the same thing happens when accelerating and releasing the gas. this problem occurs both with and without standard air filter, either with open muffler or standard silencer. I fitted boyer bransden ignition, and it is perfectly adjusted. I checked air leaks from the carburettor, but it's all right. Cables, spark, nuts and screws all tightened to perfection ... what do you think? could it be a leak from the head gasket?
