Crank oil feed issue ?blockage?
Posted: Sat Sep 30, 2017 6:50 pm
Hi, I'm in the process of rebuilding an Indian classic 500 bullet engine from the ground up. Got it all reassembled up to the point where the engine is in the frame and the primary and timing side are attached.
At this point, I thought it prudent to bleed oil through to make sure the oilways are primed and everything is getting oil like I do if I've had the timing cover off my 350. Usually by either kicking it over repeatedly or "walking" it around in gear with the plug out. So far I've bled oil through as far as the quill bolt opening. Not having much sucess getting any further and I'm pretty knackered walking the thing round now!
Anyway, every time I crack the quill bolt, it seems to be slightly pressurised but I'm pretty sure oil isn't passing through the crank. There never seems to be oil IN the stem of the quill bolt. I've removed the crankcase drain plug for the time being on the basis that the first sign of oil feed to the crank/big end will be oil coming out of here. Not a drop so-far.
I've also tried forcing oil along the end of the crank (through the pump worm seal) with a syringe. Getting a fair bit of pressure up to no avail. I'm not really sure how much resistance there ought to be here but I suspect very little? I ought to be able to force oil through with a syringe? The straw off a WD40 can goes in to the end of the timing shaft.
I'll admit to being a bit fuzzy about exactly what happens to the oil after it gets to the end of the timing shaft. I presume it makes its way up an oilway in the flywheel to the crankpin, through the middle of that then out into the big end? From whence it oozes out and drops to the bottom of the crankcase?
This leaves the worrying question of why the oil won't go through there. The crank had minimal sideways play and no vertical play when fitted and looked altogether pretty ship-shape.
I can only think of three things:
1) I have an unreasonable expectation of the pressure it takes to force oil through the crank/big end, you can't actually do it with a syringe (I'd estimate I was putting about 10kg of force onto a 1/2" diameter plunger, by "feel" about as much force as it takes to put 90psi of air into a bicycle tyre with a hand pump) and I should persist trying to prime it using the oil pump.
2) There is a blockage somewhere between the end of the timing shaft and the big end. I have some high flashpoint solvent and I'll bring my compressor back from work tomorrow and try to give it a blow through if no other ideas come up.
3) Someone has fitted the crank pin the wrong way round. This is not inconceivable, the previous owner(s) of this engine had some very neat engineering work done alongside some diabolically bad fitting. It's a 350 out to 500 which takes a degree of machining skill but there were also broken bits of piston ring in the bottom of the crankcase which shows a lacklusture degree of attention to detail. It didn't LOOK like they'd been at the crank but they might have.
I'm getting that sinking feeling that instead of having this engine running tomorrow as planned, I'm going to have to take the whole thing apart again and have the crank re-worked.
Very much open to other suggestions.
