- Sat Sep 23, 2017 7:55 am
#7731
Hi can anyone help ? i have a 2006 Electra X i revamped it over last winter nut & bolt re-build apart from the engine as it was running fine (already done 4000 mls on it) so i just painted it, then 200 mls after it went back on the road it started pressurizing the oil tank & pushing all the oil out ! ive been to all the experts/dealers & anyone that would listen, so far ive stripped it to the crank & re-built it three times ive fitted new crank seals & bearings new oil pump new rings & honed the bore even though it all looked fine. ive also cleaned all the oil ways with air & poking wire through them each time i stripped it & changed the timing case & fitted new gaskets every time (i am a 30year experienced bike mechanic but with jap bikes not British) & all of that has made no difference what so ever. ive spent 5 months & far to much money already ! has anyone had this problem before ?
